Rims (Felgen) for Toyota Prado 2021yr
need to buy 17 inch rims
Neues Thema eröffnen   Neue Antwort erstellen    Offroad Forum Foren-Übersicht -> English Forum Beiträge seit dem letzten Besuch anzeigen
TLC Prado
Mit dabei seit Mitte 2021
...und hat diesen Thread vor 1844 Tagen gestartet!
BeitragVerfasst am: 31.08.2021 12:39:29    Titel: Rims (Felgen) for Toyota Prado 2021yr
Hay ,
I wanna buy 17 inch rims for my Toyota Land Cruiser Prado (Germany), with offset 00.
Can someone give me a direction where to search.
THNX
RallyeCopilot
Mit dabei seit Ende 2014
1. D
2. E
3. F
4. E
5. N
6. D
7. E
8. R
9. Sabo 2-Takt-Rasenmäher
BeitragVerfasst am: 20.09.2021 13:50:07    Titel:
Can you tell me the year of production and your favourite width of the rim in Inches? I suppose all the Prados have a PCD 6 x 139,7mm. Should be the same as HDJ80. May be I can help you with EvoCorse wheels.
TLC Prado
BeitragVerfasst am: 28.09.2021 06:08:30    Titel:
Thnx for the answer. Its a 2021yr model. I would like to change my 19 inch rims for 17 inch , with 265-70 tires. In Germany its very hard to found ( approved/with ceritificate )steel rims.
The size of the tires , that I wanna use is also not allowed. I dont get it, there are hundred of thousands Prados in Australia with that size legaly, but but in bloody Germany , where you can count the Prados on the finger,
its not allowed.
RallyeCopilot
1. D
2. E
3. F
4. E
5. N
6. D
7. E
8. R
BeitragVerfasst am: 28.09.2021 14:09:23    Titel:
Is there enough space for the brake calipers to fit 17" rims?
If there is no german certificate for your tire size things get complicated.
The EvoCorse rims have the load index stamped in. If you can get an information from Toyota which tire sizes they permit it should be possible to get that all street legal.
My experience is that you can only vary the tire sizes of newer cars in a very small range of some percent.If the tires become bigger or smaller the homologation for the CO and NOx emissions will not be valid any more.
I´ll try to find out which sizes can be legalized in Germany. If you find out something just post it here.
TLC Prado
BeitragVerfasst am: 21.11.2021 07:36:16    Titel:
Its allowed to use 265-70/17 for 2021 Prado, but the problem is there are no "legal" rims to be found , absolutly nowhere, in a search for almost 3 months and NOTHING!
Scap
Lottogewinnvordrängler
Mit dabei seit Ende 2020
BeitragVerfasst am: 21.11.2021 11:24:03    Titel:
There are 7x17 Dotz steel rims, legal and fitting J15 Prado.
What Wheel size does your Prado mount originally?
UrbanHeintze
BeitragVerfasst am: 16.12.2021 10:57:38    Titel:
I believe 7x17 isn't wide enough, because even the stock rims for EUDM Prado are 7.5" wide. 17 is the smallest standard size for the 2021 Prado, but I do understand why the OP wants to go with the 16s...and yeah the majority of LC in other countries run much bigger tires and lifts with no problems.
You can check some Prado rims here: https://www.wagens.de/felgen/toyota-land-cruiser-prado-2021/?submodel=0
but they all come in 17" size with standard ET (no 0-offset is available).
Toyota Hilux Comfort
TLC Prado
BeitragVerfasst am: 12.10.2022 11:09:13    Titel:
Finnaly I got some rims from Borbet , not the best, but the olny one with certificate.
So, with 265/70/17 totally different story.
Thnx for hepling me ...
Does anyone live near FFM Germany, wanna hang up a little bit with people with similiar hobbies.
